RB450G new, open a terminal and when I saw someone change the message on the terminal by another promoted.
How can we change it? and how? I wish I could change.
thanks for any help.
Contact support@mikrotik.com.
Maybe this is only system note added?
http://wiki.mikrotik.com/wiki/Manual:System/Note
HTH,
The text I mean is this:
how I can change? how?
Thanks for you help!!
what is changed? this is the default text.
if you want to add your own banner, use the SYSTEM NOTE as mentioned above
Hello dear Normis.
please sorry, these message:
Thanks for your help
this is available to mikrotik distributors and resellers. if you are one, email support
Ok, Thanks!
Hello all,
I have been reading this.
My question is when it is not possible to change the default text “Mikrotik” is it then possible to disable it so you will not see the text “Mikrotik” ???
Please respond on this one.
that is stupid, router is mine so I should decide what banner to use. Like Cisco or HP routers is up to user nor reseller ? please allow this to all owners.
