If I change the default winbox port og 8291 to different port, how can I change in winbox software to change the same to get secure login
Very simple. In Winbox:
/ip → services, click on “Winbox”, and set port you want.
Here you can also change SSH port etc.
In the Winbox connection setup window, you simply add :your-new-port after the IP address.
