How to check which devices are using specific ETHERNET / WLAN interface?
Hi!
Again, I need Your help good People :slight_smile:
Is there any way to see which devices are using ETHERNET / WLAN interface? I already know how to check current connections, but I can’t find a way to connect devices with interfaces. If I’d like to check which WLAN (2.4GHz or 5GHz) my computer is actually using, where should I look (in RouterOS)?
Bridge > Hosts in Winbox / Webfig lists the MAC addresses seen on each of the bridge ports (both ethernet and wireless).
Wireless > Registration only lists the MAC addresses of any clients associated with wireless interfaces, but has additional data (signal strength, data rates) available.
Thanks for such a quick response!
Under hosts, I see one MAC i don’t have in DHCP Server table and also, I can’t remove it from under hosts. This MAC is using both ethernet (eth5) and WLAN interfaces. Could it be it’s part of a bridge (RouterOS thing)? It has label D (dynamic) and L (local).
check for mac on IP DHCP Server leases as well.
I did that and there is no such MAC.
EDIT:
Turns out MAC address vendor is Routerboard.
Entries with the L flag are the interfaces on the Mikrotik itself, you can ignore those.
