kovalr
April 4, 2018, 1:59pm
1
Hello!
This is my script
:local time [/system clock get time]
:local hour [:pick $time 0 2]
:local minute [:pick $time 3 5]
print file="$hour.$minute-udp-testfile.txt" stats where action =log
/ip firewall filter reset-counters numbers=5
Last command
doesn’t work in script but normally work in Terminal. Why?
Hi.
Try to use script only with one line
It could be a problem with the previous lines in script.
The answer is “Because 5 is valid only after ‘print’ command and can point to any firewall rule, so don’t use this command in scripts”. The correct way is
/ip firewall filter reset-counters [find comment="bla-bla-bla"]
or kind of
