larmaid
February 19, 2007, 6:02am
1
hi im having a small problem, i just setting a new mikrotik (2.9.27) and i want to connect with my other mikrotik (2.9.7)
here r the ip config =
mikrotik 1(2.9.7) =
ether 1 → 10.10.0.xxx (local)
ether 2 → 202.165.xxx.xxx (global)
mkrotik 2(2.9.27) =
bridge1 → 10.10.0.xxx (i connected 4 ether with bridge1) (local)(reply-only)
ether5 → 202.165.xxx.xxx (global)
right now i connect to mikrotik 1 using ether1 the problem is i cant connect to local network on mikrotik 2…!!!
here is my nat on mikrotik2 =
chain=dstnat | action=dst-nat | to address=10.10.xxx.xxx | to-ports=0-65545
anyone can help me …
thx
janisk
February 19, 2007, 7:00am
2
this “bug” is solved in 2.9.40
larmaid
February 19, 2007, 7:16am
3
is this a “bug”…
so your saying that my configuration is right…!!!
janisk
February 19, 2007, 7:26am
4
ok. check your routes - if everything is ok, can you ping current nework (set on interface) can you ping one further.
and i encourage you to use newest version of RouterOS that would be 2.9.40 as it is recommended.
larmaid
February 19, 2007, 7:31am
5
my routers is OKAY, but the problem i cant connect to mikrotik2 local network…
larmaid
February 19, 2007, 7:37am
7
the local network on MT2 is OK & the machine MT2 is OK, so whats wrong???any solution..???, btw janisk can i contact u by YM…???
janisk
February 19, 2007, 8:37am
8
please post ip address configuration
ip route configuration here of both routers.
and as i have understood than MT2 default gateway is MT1 right? or what you want to achieve with this configuration, that both routers have real ip address
larmaid
February 19, 2007, 9:03am
9
okay here r the all most configration :
mikrotik1 =
ether1 → 10.10.9.99/16 (local)
ether2 → 202.165.xxx.xxx (global)
gateway → 202.165.33.xxx (cisco gateway)
mikrotik2 =
ether1 → no ip (bridge1)
ether2 → no ip (bridge1)
ether3 → no ip (bridge1)
ether4 → no ip (bridge1)
bridge1 → 10.10.10.99/16 (bridge local)
ether 5 → 202.165.xxx.xxx (global)
any solutions…???
time is closing…
janisk
February 19, 2007, 9:12am
10
larmaid:
mikrotik1 =
mikrotik2 =
any solutions…???
time is closing…
so there is no physical link to MT2 other than through your cisco Gateway, is it?
normis
February 19, 2007, 11:04am
12
please upgrade, there is no reason not to
