hi,
does anyone has any idea about how to config a hotspot using RB750 + Nanostation 2.4 ghz? i have attached a pic my network
regards
Rather easy, actually.
Make a bridge:
/interface bridge add name=HS-bridge protocol-mode=rstp
… put ETH2 and ETH5 into a bridge:
/interface bridge port add interface=ETH2 bridge=HS-bridge
/interface bridge port add interface=ETH5 bridge=HS-bridge
… and follow HotSpot setup:
/ip hotspot setup
Pay attention to build the hotspot on “HS-bridge”. This way, all the clients (wired and wireless) will be getting DHCP assigned IP from the same subnet (E.g.: 192.168.1.0/24).
Otherwise, if for some reason you have to have them in separate subnets, you have to setup a hotspot on each ETH separately.
Here is a nice reading: http://wiki.mikrotik.com/wiki/Hotspot_server_setup
And there you go … Rather basic, as I said.
thanks for the reply Denis, i did that just in a more simple way…
i just assigned in bridge mode the nanostation device with ip 192.168.2.1 and then i build the hotspot setup on the same ethernet port with ip range 192.168.3.1/24 and that’s it ![]()
thanks anyway and cheers to normis ![]()
I am having a similar issue, I have ether 1 setup as dhcp client for ISP. Ether2 is setup as wlan with ip of 10.5.50.1, both ether 1 and wlan have no master. Ether 3 is master to ether4-5 with an ip of 10.5.51.1. My wired clients on ether3-5 only receive ip and subnet, they don’t receive DNS or gateway settings, how can I correct this?
/ip dhcp export
/ip hotspot export
i have rocket m5 90 degree sector and a pc routerboard v.5.20 with levl6.i want to make the following:
1)create AP in rocket m5.
2)sxt as station and connect to Rocket m5.
in the sxt and i want to hve hotspot link from my pc routerboard v5.20 which i want to manage it frm the pc..
any help appreciated..
thankz is advance.
