Dear experts.
I recently buyed 4 SXT 2. i want to acomplisch to establish two wireless bridges. Creating one bridge goes fine. but when i putting the second bridge online the whole thing give no replys on pings. i allreade disabled STP protocol on the bridge.
i hav e a feeling this hase something to do with the ROOT bridge.???!??
Network details.
172.16.10.0
255.255.255.0
Mikrotik1a 172.16.10.20
Mikrotik1b 172.16.10.21
Mikrotik2a 172.16.10.22
Mikrotik2b 172.16.10.23
On the second bridge ia have a difrent frequentie, WPA key, SSID.
PLease any help is welcome!
GR
Stevo
I think your issue is the ip subnet.
Two interfaces cannot have a ip in the same subnet because of the Routing.
Create the one bridge in 172.16.10.0/24 and the second in 172.16.11.0/24
What will this links be used for?
It may be better to do routing instead of bridging everything.
Thanks for the reply.
so the situation is like this.
i want 2 (Ruckus) accespoints on 2 difrent locations distance between Ruckus AP en Switch is 300 Meter so i need two wireless (bridge) connections to both locations. one connection per accespoint.
Is there any documentation in achieving this goal?
Hello guys
My distributor solved the problem.
problem was having 2 of the same mac adresses on the interface. I have backup device one and restored it on device 2. so that was not the way. now i learned how to export my config within the CLI.
Thanks for the reply’s problem solved!
gr
Stevo
