Both the Fritz!Box 7340 and MikroTik hAP ac lite router currently act as DHCP servers, effectively splitting the network in two LANs. The MikroTik router was also configured as a bridge for the
All DHCP and NAT should be handled exclusively by the Fritz!Box. Furthermore, the MikroTik hAP ac lite should have a static IP address in the same local IP address range so it can still be managed over its web interface.
The Fritz!Box configuration is not an issue. However, I am an utter newbie managing MikroTik’s RouterOS and I found no instructions on the web concerning this specific problem. Hence, my question:
What are the (detailed) steps to configure a MikroTik hAP ac lite as a Layer 2 switch, removing its DHCP server whilst keeping a static IP address for management?
By the way, I am on GNU/Linux, so using Winbox is not an option for me.
IP > DHCP Server, delete the dhcp server for bridge-local
IP > Addresses, replace IP address for bridge-local to your desired IP (192.168.178.x/24)
At this point, Ports 2-5 and wifi are considered a switch. ether1 remains the gateway. If you want to use ether1 as another port in the switch…
IP > DHCP Client, delete DHCP Client for ether1
Bridge > Ports, add ether1 to bridge-local.
IP > Firewall > NAT, delete the masquerade rule
That’s about it I think.
When I make a Mikrotik into a switch, I usually don’t assign a static IP to the switch, rather I use DHCP instead. Winbox will detect it, and it’s one less static IP to make note of.
IP > DHCP Client, Add, interface = bridge-local (instead of adding IP via IP > Addresses)
I also set the identity to something useful so if Winbox detects 10 switches, they show up with their identity in the list.
I also set up NTP so the switch polls NTP servers for the correct time. Helps with troubleshooting and reading the log file.
On the MikroTik support pages, I came across an article about how to configure a DHCP relay.
It is not clear to me whether a DHCP relay is the same thing as a Layer 2 switch or just part of it?
Thank you for your very useful answer. I forgot to mention that I cannot use Winbox because I am on GNU/Linux. Would below statement still stand for the web or command line interface?
If you can’t use Winbox, then a static IP may be easier/simpler. There is no way for a web browser to detect Mikrotik devices on the network, you’d have to know the IP to connect. I heard winbox works with WINE for linux.
DHCP relay is not the same thing as a layer2 switch. With the Mikrotik configured as a swtich, all packets will flow through it. So a DHCP request will be fulfilled by the router (or whatever is handing out DHCP).
Typically a LAN has its own DHCP Server. A DHCP Relay is for when you have multiple LANs but the DHCP server is on a different subnet.
