How to configure BGP between Mikrotik and Cisco
Hello All,
I have configure BGP with Mikroti and Cisco without loopback address, which was successful but I when I had used the loopback address than I faced some problems into mikrotik router. I had check the BGP status over Cisco router with loopback that was established and also check into Mikrotik router with loopback I found established.
But I was unable to connect the computers connected to the cisco router however I can able to connect computers connected to the mikrotik router through BGP (from cisco lan).
After that I had check the routing table into the mikrotik I seen there was BGP route but was in blue colour.
Pls suggest me how to configure BGP with mikrotik and cisco with loopback interface.
Thanks in advance
Rosan
I think you are receiving bgp routes with wrong next hop address. You have two options
to solve this problem.
1 - if you have access to cisco, try to force next-hop and/or look if your update-source is loopback.
2 - you can make a input filter that foce next-hop to correct IP.
I recommend the 1st option.
Jorge
Also look at this article
http://wiki.mikrotik.com/wiki/Using_scope_and_target-scope_attributes
