my question is i am configuring an access point. currently i have configured them as ap bridge and client are connected through ip range (10.210.2.2-254)and 10.210.2.1 is the gaeway for all client.now i want to all access point work as gateway for the wireless client.(there is no hotspot )
only access point (411ah configured as ap bridge mode 2.4).
i am submitting the image of my network setup.
is this correcet setting or not bcos last time when i configured with same setting one of my 411ah board goes down (i have been posted in the foram )
so kindly suggest me the process is correct or not ???/
after creating dhcp server and pool.and selecting the wlan as dhcp server interface then it will work.
bcos last time i was doing the same thing.but routerboard was damaged and never worked after that.
so i am asking this is the correcet process or not ???
so try to understand my friend ??? don’t mind
one more thing (after assinging the ip to wlan winbox will show two ip one for ethernet and one for wlan ???
hole day i was trying to configure the 411ah as access point (ap bridge)
ehternet1 ip 10.210.2.5/24
wlan1 ip 192.168.1.1/24
bridge1 =ehternet and wlan1 (briged)
dns=192.168.1.1 ,10.210.2.1,4.2.2.2
pool =192.168.1.2.-254
dhcp server=(192.168.1.1 interface wlan1)
and after that natting
chain=srcnat out- interface ether1 and action masquarade
dafault route 0.0.0.0 10.210.2.1
when i the dhcp server interface on wlan1 it becomes red and when i select bridge it is in normal ok
i don’t know what to do for this ???
any suggestion
