How to configure inter VLAN routing?
How to configure inter VLAN routing using Cisco 6009 switch and 7200 router?
Hmmm… I hope you’ve noticed, that this is a Mikrotik forum. It’s also the Wireless branch of the forum…
I guess you need to configure dot1q subinterfaces on an interface of the 7200, configure a trunk port on the switch and connect it together… Then hosts connected to different access vlan ports should communicate via the router…
Thanks “jacekes” for help.
