Hi, I am a newbee to MikroTik products, so It’s a steep learning curve for me. I purchased an LHG-LTE6 kit in hopes of using it as a modem for communicating with AT&T cell data (towers), and connecting the ethernet side to my Ubiquiti UDM firewall router. The physical connection is obvious, PoE supplied by router switch, but configuration is a little confusing. I am using a MoFi-4500 as the modem currently, but thought MikroTik might be a better solution, certainly cleaner with PoE and the single connection to modem.
Any help will be appreciated. Maybe walk me through a complete setup. I do have WinBox64 and it connects successfully to the unit.
Larry.
