How to configure route between gateway / lan bridge?
Hi guys,
I have the following conf which works (two networks) , but I think I need to modify it to one network as I want to see from a PC conected to to ether2 (bridge) all devices attached to all other ports of the Fritz!Box:
Hardware: RB 951G-2HnD
  • ether1 connected to a Fritz!Box which is also the Internet AP - network 192.168.172.0
  • ether2 - ether5 and wlan1 as a bridge - separate network 192.168.2.0
  • DHCP server on the RB
  • masquerading supported
  • cannot see the devices contected to the other ports of the Fritz!Box
One single network:
  • ether2 - ether5 and wlan1 as a bridge in the same network - IP range 192.168.172.0
  • DHCP from Fritz!Box connected to ether1
  • see all devices contected to all ports of the Fritz!Box
Assuming that the routes on the RB have to be entered manually to get rid of the DHCP server on the RB. And is masquerading still supported, even being in the same network?
Final target is to manage the traffic before it affects the overall Fritz!Box-traffic as the bandwidth limitations provided by the Friz!Box do not fulfull the bandwidth management needs.
Please advise what to change to get this working.
Thanks!
Current config:
add name=dhcp_pool0 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 authoritative=yes bootp-support=static disabled=\
    no interface=bridge-local lease-script="" lease-time=3d name=dhcp1 \
    use-radius=no
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.2.0/24 caps-manager="" dhcp-option="" dns-server="" \
    gateway=192.168.2.1 ntp-server="" wins-server=""
/ip dhcp-client
add add-default-route=yes comment=wan-ip-address default-route-distance=1 \
    dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=\
    yes use-peer-ntp=yes
Hi Sky18,
thanks for this very helpful script. No I can plan the transfer of the dns-server from my router to separate machine. Too sad, that MikroTik this haven’t buildin.
Ulf
Based on your description, it doesn’t sound like you need the MT at all. Just connect the Fritzbox and PC (on ether2) to the same switch.
If the MT is your only switch, the easiest thing might be to move the Fritzbox from ether1 to whatever is open on ether2 to ether5 and disable the DHCP server on the MT.
