How to configure RouterBoard CCR1009-8G-1S-1sPlus
How to configure Router Board CCR1009-8G-1S-1sPlus with Static IP Addresses from ISP and how configure DHCP after it?
thank you
Hi
how do you connect to internet ?
for example : PPPOE , PPTP , Link Wireless,
if you use pppoe ,you should create pppoe client then ip will be set on your router
http://192.168.88.1/
login as admin with no password
Use the Quick Setup.
Then you can learn more here: http://wiki.mikrotik.com/
