I bought Mirkrotik RB2011UiAS-2HnD-IN, I have managed to configure the port 2 for DHCP and wanted to make it the master for all other interfaces,
when i check the other ports i don’t see the Master feature.
I urgently need your help[
If you have upgraded your router to 6.41 then there is no master-port anymore
https://mikrotik.com/download/changelogs/current-release-tree
What’s new in 6.41 (2017-Dec-22 11:55):
Important note!!! Backup before upgrade!
RouterOS (v6.40rc36-rc40 and) v6.41rc1+ contains new bridge implementation that supports hardware offloading (hw-offload).
This update will convert all interface “master-port” configuration into new bridge configuration, and eliminate “master-port” option as such.
Bridge will handle all Layer2 forwarding and the use of switch-chip (hw-offload) will be automatically turned on based on appropriate conditions.
The rest of RouterOS Switch specific configuration remains untouched in usual menus for now.
Please, note that downgrading to previous RouterOS versions will not restore “master-port” configuration, so use backups to restore configuration on downgrade.
