how to configure the two public(uplink) ips in mt
hi, MT gurus please send the configuration and route the two public gateways configuration in MT
Public1 202.4.xx.25
Public2 202.1.xx.35
Local 10.10.x.x
thanking you,
Myst
See this page: http://wiki.mikrotik.com/wiki/Routing If you can’t understand the suggestions on that page (there are 3 or 4 of them), then you should hire someone to assist you. You can find someone to assist with that here: http://www.mikrotik.com/consultants.html
you want that the request should go via both the gateway.
If yes than do Load balancing.
