Please i need someone to explain to me on how to configure vlan in RB 750 and also how i can use RB750 to route the vlans.
i have done some configurations on the routerboard, i am only able to browse with only one subnet of IP address but the other ones i can browse with them.
attached is the RB750 export config i did on the board and also the config on the cisco 2950 switch for any one to look at and make corrections.
I would appreciate quick response.
cisco2950 vlan config.txt (5.26 KB)
vlan_backup.rsc (16.3 KB)
The only things that stick out to me:
/interface vlan
add arp=enabled disabled=no interface=ether2-local-master l2mtu=1520 mtu=1500 \
name=vlan1 use-service-tag=yes vlan-id=1
name=vlan2 use-service-tag=yes vlan-id=2
name=vlan100 use-service-tag=yes vlan-id=100
use-service-tag should be set to ‘no’, and while you can have a VLAN id of 1 in an 802.1q header Cisco treats VLAN 1 as native by default, and does not tag it. For this to work on the RouterOS side you’d have to enter the ‘vlan dot1q tag native’ global command, or change the native VLAN on the trunk to the router via “switchport trunk native vlan ”, with x being a VLAN id that doesn’t exist in your switch VLAN database.
add address=192.168.88.1/24 comment="default configuration" disabled=no \
interface=ether2-local-master network=192.168.88.0
add address=192.168.70.45/24 comment="WAN LINK" disabled=no interface=\
ether1-gateway network=192.168.70.0
add address=192.168.1.254/24 disabled=no interface=vlan1 network=192.168.1.0
add address=192.168.2.254/24 disabled=no interface=vlan2 network=192.168.2.0
add address=192.168.100.254/24 disabled=no interface=vlan100 network=\
192.168.100.0
You may want to remove 192.168.88.1, the default configuration IP address. Right now that IP is active on your VLAN 1 since as explained above VLAN 1 is coming in as untagged frames.
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
default-route-distance=1 disabled=yes interface=ether1-gateway \
use-peer-dns=yes use-peer-ntp=yes
You have a static IP for the WAN, remove the DHCP client (this doesn’t hurt anything, but isn’t needed).
add action=masquerade chain=srcnat comment="default configuration" disabled=\
no out-interface=ether1-gateway
add action=masquerade chain=srcnat disabled=no src-address=192.168.1.0/24
add action=masquerade chain=srcnat disabled=no out-interface=ether1-gateway \
src-address=192.168.2.0/24
add action=masquerade chain=srcnat disabled=no src-address=192.168.100.0/24
You can remove all but the first line, which in English means “when traffic leaves the router through the WAN interface, source NAT it to the primary IP address configured on that interface”. The other rules are never used.
