how to connect a RB751 to a TP-Link access point
Hello guys ,
I Have a network connection with two TP-Link point to point connection and now I need to increase the range, I have a RB751U-2HnD and I don’t know if it is possible to connect this one to those TP-Links access point
please help me I’m in Afghanistan and I couldn’t find anyone that be expert in mikrotik
thanks! :frowning:
I have never used TPLink but it shouldn’t be any problem. Are you wanting a repeater or just another access point off the PtP link?
Yes I want to use this RB751u-2hnd as a repeater
I have connected them and assign wireless mode to ap bridge with wds
but when i power on the RB751U-2Hnd I can’t access internet!
Do you have WDS enable on the TP-Link? Does the AP-Bridge have any registered WDS connections?
No it has not
but i configure it with point to point on TP-link and WDS on RB751
Thank you for replay
RouterOS WDS is not compatible with TPLink WDS. Usually each manufacturer has it’s own WDS implementation which only works with their own devices.
