I have a 750 VA APC Smart UPS and a RB1100.
I got connected the serial port from UPS to Console RB1100 and in Winbox when I try to add the UPS on serial0 it say:
Couldn’t add New UPS - port’s channel is already in use (6)
RB1100 doesn’t boot with RS232 APC UPS (Smart-UPS 620I) connected. If I connect UPS after boot ROS, everything working fine. ROS version 5.5, latest firmware.
Any idea?
I have RB1100 and smart UPS connected with APC RS232 cable, I upgraded boot loader to version 2.38 and the RB1100 doesn’t boot anymore.
Do you think it might be same problem with RB1100 and Smart UPS connected, It have worked without problems up to now before upgrading boot loader and I have rebooted RB1100 several times with Smart UPS connected.
Do you think, that RB1100 is actually detecting UPS on RS232 as console input and RB1100 goes into setup mode.
My RB1100 is on remote location otherwise I would disconnect RS232 already, I’ll tell someone to disconnect RS232 cable from UPS and hopefully if RouterOS will load, I will change Enter Setup on DEL key.
hello
dear friend
i have a RB433AH and a Tatung-TCU200 plus
i want to send SMS bye serial port on routerboard
how to install a configur it ?
plz help me
