There is local net based on 2011. Try to cinnect to 2011 using android app from Googleplay - unable, not from local (using 192…,) not from outside (using provider’s IP assigned to Mikrotik).
In Services disable all excluding Winbox, trying to enable app / app ssl - not helps.
How can I connect?
Rules in attach.
Problem solved by adding new rule in firewall - add chain=input action=accept protocol=tcp in-interface=ether1-WAN dst-port= **** log=yes log-prefix=“winbox”
Hello Pablo,
I’m glad you solved your issue but did you realize you created a new one?
It’s not a good idea to open WinBox on your WAN port. It’s a major security risk.
You’d need better off doing at least port knocking first or, better yet, VPN to your router before managing it.
Regards,
Sent from my cell phone. Sorry for the errors.
I don’t recommend using the app from the WAN side, for many reasons (mainly security) other than its just in beta.
However if you can open a VPN to home and then use the APP as though you were on the LAN, that may be a different story)
Am I hearing an echo here? ![]()
Just trying to get the message through, loud clear and often. ![]()
We make a great team!
PS I will bet you didn’t know I was born in
Hôpital du Saint-Sacrement. So your like my south western french bro!
I have a OpenVPN server on my router and the OpenVPN app. So I can connect to my router from the outside and then use the TikApp to control my router securely.
