Good day! Can someone help me about my current situation. I have a RB750Gr3, I have set its ARP to reply-only as suggested here in forum if you want the clients to have a connections only using DHCP lease. I have a network of 10.75.16.0/22, 10.75.17.1 is the gateway. Now we have some few CPEs which have a static IP of 192.168.10.0/24 range. Now I want to connect to the CPE devices without disconnecting my network and manually encoding the IP of my PC to the CPEs IP range. Any suggestions how to go about it?
Configure your cpes as bridge and set it an IP address or if is routing, use the static wan IP of your cpe.
On worst case use Mac address to connect. Winbox
Thanks for the fast reply. Sorry, I forgot to say that it was in bridge mode. Everytime I wan’t to connect to the devices, I need to set static my IP to the CPEs range. CPE’s are Ubiquiti Rocket M5’s and Nano Beams. I can connect to workstations which are connected to these CPEs.
