How to connect private IPs through Mikrotik
Dear Fellows,
I have a problem and can not get how to override on it.
I have a remote site with Mikrotik 750 router with Live IP 202.146.X.1/29 and 2 Wireless device one is AP and second is client with the IP address 172.20.60.2/29 and 172.20.60.3/29.
What I need is that I want to connect these wireless devices web interfaces from remote sites.
Please advise me some solution
Looking forward for your prompt reply
hi
you have different way.
1.you can run VPN Server In main Router That connected to internet and create vpn connection in your remote pc to get invalid ip address in range that wireless has.with this vpn you can ping and open that ip.
2.you can use from dst-nat.you must config ip firewall nat,dst-nat your public ip to invalid wireless ip address.
if you want i can send for you export of config.
