Hi, I have a SXT cpe out at a remote location that seems to have been factory reset and looks like its running the default config. I have it registered to a test AP bridge, its clearly in station mode. I can mac-ping it, but cannot mac-telnet. I have a dhcp server set up on the wlan of the AP bridge, but I dont see any packets coming in the wlan (apart from mac-ping relies).
Any tips on how to get in and configure it? Thanks.
I don’t think default config is in station mode.
from /sys default-config pr
#| CPE RouterMode:
#| * wireless interface connected to providers network (WAN port);
#| * WAN port is protected by firewall and enabled DHCP client
#| wlan1 Configuration:
#| mode: station;
#| band: 5ghz-a/n;
#| ht-chains: 0,1;
#| ht-extension: 20/40mhz-Ce;
#| LAN Configuration:
#| IP address 192.168.88.1/24 is set on ether1 (LAN port)
#| DHCP Server: enabled;
#| DNS: enabled;
#| WAN (gateway) Configuration:
#| gateway: wlan1 ;
#| ip4 firewall: enabled;
#| NAT: enabled;
#| DHCP Client: enabled;
Looks like station mode, its associated to my bridge and wds is off, so what mode would that be other than station mode?
