how to connect to RB when Ehternet1 interface is disabled ?
I have disabled the Ethernet 1 port by mistake through Winbox. Now I cannot connect to routerboard thru ethernet port. I had not configured WLan yet, thus I cannot even connect to Wlan1 thru winbox and enable the Ethernet1.
I guess the only way I can connect to RB is using Console Cable.
Do let me know if there are any other ways to connect to RB.
I have never used Console cable earlier, so do give me a assistance on how to connect to console cable.
Regards,
dxnation
Hai fren,
yes, you can connect with serial null modem, and you can make by yourself it cable with this diagram.
HyperTerminal Windows will help you application for... :wink:
regards
Hasbullah.com
Thank you very much my dear friend.
I will try to follow this.
Hi ;
Thanks alot for this diagram , i will keep it for future use .
here i put a qusetion , if i am using a pc as MT OS . can i use this null console cable to login the server ?
with best regards
Hai fren,
so sorry, i never try with my x86 router, i used it for all my RBs when i have hard problem.
cause my Centralized AAA with PIII-500Mhz 512RAM ROS-L6 stable in v2.9.49, and until now i don't have problem about it
regards
Hasbullah.com
yes, you can remote PC using serial cable,
but maybe you have to set several settings on PC BIOS before you can use it.
Hi ;
Thanks for your reply .
could you give us an idea what we should do to the BIOS configurations ?
with best regards .
I was not successful with the console cable however, I had 2 ethernet interface in the RB so I connected to the second Ethernet port and logged in.
