Hi!
I have two lans in different areas. Every lan have static IP. like 88.196.12.10 and 88.16.72.107 as example.
How I can connect these two LANs as local LAN?
I have Mikrotik Dude Edition RB1100AHX4 in every lan.
Hi!
…use a GRE-Tunnel to either site with a small transfer net accross the tunnel (use a /30 address on each of the tunnel endpoints)…you can as well enable IPSec inside the GRE Tunnel if you think that is useful (I don’t).
Also read up on EOIP!
Just use EoIP, or maybe L2TP BCP if one endpoint doesn’t have a static IP.
