hello ,
please help me to convert my http file transfer server to any address
I need to use internal ip address like 192.168.128.27 to open when any client in the network type www.trk-server.com
i tried to use dns but not working
when I try DNS method in old version mikrotikOS like 2.9.27 .. work fine
this isn’t working with any newer mikrotik versions
are there any method to work with this ???
thanks anyway
I think it is possible to redirect any DNS request to your DNS server on RouterOS with help of dst-nat. In DNS server configuratuion on RoS you can bind desired address to 192.168.128.27 and forward request to it.
Please let me know if you need configuration assistance.
If you run DNS caching on your Mikrotik and have your client’s DNS server set to that of your Mikrotik, then the DNS method should work.
Alternately you can do a dst-nat, protocol=udp, dst-port=53 with action redirect, it will grab any DNS requsts and proxy them…provided you have enabled DNS caching.
