Does anybody know how I can dynamically create a script in MT from a txt file on the box ?
I want to be able to have a script which runs every 1 minute or so, and that script reads a file in from the router, which is FTP’d to the router, and then creates a script from that file which is then executed. I want to be able to do this so I can generate a script based on a certain externally determined criteria. Then create a firewall rule based on that information.
Any help would be greatly appreciated.
Regards
Paul
