i will state my case briefly:
i am a small ISP arround 85 users
for the time being i use mikrotik only as a bandwidth limiter.
I am planning to use user manager
All my pppoe users are static because i assign the username to a router as TPlink router so can all pcs and mobile connect threw this router at the end client.
what i need in some way
an automated regeneration code to reactivate the same pppoe user not to create a new user …
can someone help me ? if possible
I cannot each time go and access the tp_link router and tell users to change the pppoe account
i need in a way to regenerate a code that can reactivate the pppoe-user
is this possible using user manager
it can be done or not just a simple advice
PPPOE users
i need to regenerate a pincode to reactivate the same pppoe username and password when the account expire???
using usermanager
If you’re not strictly stick to usermanager, you may have a look at http://accessmanager.in. It allows you to generate recharge vouchers with PIN, and hand out those PINs to your clients renew/recharge their account.
Thank you!
