Dear ALL:
Please let me know how to create a queue for the bandwidth 128K/64K and shared it with 3 users. Thank you in advance
Best Regards
Vasi Akhter
Dear ALL:
Vasi Akhter
just add 3 target addresses.
Please dear can you give me an example. i tried PCQ from mikrtoik but it is giving 128/64K to each customer. I want to share 128/64k between 3 users.
Thank you very much in advance dear. Please help me in this
You use simple queues and there are 2 little arrows on the right next to the ‘Target Address’ field, click the arrow pointing down and add your 2nd ip address then click the down arrow again and add the 3rd address then put in your Max Limit’s up and down.
what if i want to do the same but using hotspot. i have 3 profiles. i have a profiles limited 64k up/ 256k down128k up/ 512k down, and 256k up/1024k down, i want to do a share ratio 1:5. so i want the first 5 users logging from a certain profile to be added to that queue, and so on. is that possible?
