how to create PPPoE on mikrotik 5.22 ?
hi youth
i want to used PPPoE system on my routerboard 750gl can i found lessons about this system ?
thanks!
Do you want an PPPOE server or client (client is the one that you use to connect to the internet to)
http://wiki.mikrotik.com/wiki/PPPOE_Server
http://wiki.mikrotik.com/wiki/Manual:Interface/PPPoE for the client.
if you have any other questions please ask.
thanks for replay but this method used before merge did used after merge on routerboard !
I actually don’t know what you are trying to say.
