hello to everyone…
first of all: before i was working in a ISP, and they was working with mikrotik routers to menage their networks, after some time they gave me access to all mikrotik routers and i started working in some small things in mikrotik, for example registering a new user, removing them, queues , ARP’s etc…
after that i have been accepted in municipal institution and they have internet connection, but they are using small bridges for 180 computers LOL!
i have bought one mikrotik license, and i installed in a pc .. and it’s running well, i was looking to find which mikrotik lan cards and wireless lan cards can be used and are known by mikrotik system..
let me explain me what i want to do : I want to put two lan cards in the pc i installed mikrotik , and enter ADSL connection in the pc (incoming connection ) and i want to use another LAN CARD to output the connection!!
Can someone tell me : what kind of Lan cards should i use that will work with these 200 clients, and how do i create two lan interfaces in mikrotik router system, or WHAT SHOULD i create in mikrotik to make this system working!!!
Your help is appreciated
Thanks a lot!
There is a list of supported Ethernet chipsets:
http://wiki.mikrotik.com/wiki/Supported_Hardware#Ethernet_chipsets
Usually Intel is best choice.
HTH,
Yeah,
Thanks for the link you provided!
Can someone explain me about Mikrotik Router configuration now ?
how to make this router working and connecting to the internet thru ADSL and creating another interface output with LAN CARD to output the internet connection to all municipal computers!!?
Thanks!
