Hello all,
I like to create on my RB962UiGS-5Hac two vlan and two dhcp servers.
On port2 i like to have vlan10 and dhcp server 10.0.0.1 (trunk),
on port3 vlan20 and dhcp server 20.0.0.1.
How to create?
Just do exactly as you wrote yourself:
- Create vlan-interface on top of port 2 with vlan-id=10
- Create vlan-interface on top of port 3 with vlan-id=20
- Assign addresses to this vlan-interfaces
- Create DHCP servers on top of this vlan-interfaces
As a result the traffic on port2 and port3 will be tagged by corresponding vlan tag.
And you will have a dhcp running for each of the vlans.
Only note that 20.0.0.1 is not a private address, so in real setup it has to be something else from the private ip’s range.
In addition to steps, described by @xvo, perform also this step:
0) remove port2 and port3 from any bridge
If you want to have those two ports members of bridge (e.g. to switch untagged traffic between these two ports and rest of your RB), then setup is slightly more complex.
