How to Create wifi interface?
Hi all!
Router [admin@MikroTik] > system/routerboard/print
routerboard: yes
model: L009UiGS-2HaxD
firmware-type: ipq5000
factory-firmware: 7.12.2
current-firmware: 7.14.3
upgrade-firmware: 7.14.3
[admin@MikroTik] > /interface/print
Flags: R - RUNNING
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAX-L2MTU, MAC-ADDRESS
NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 ether1 ether 1500 1600 8158 D4:01:C3:22:75:52
1 ether2 ether 1500 1596 8154 D4:01:C3:22:75:53
2 ether3 ether 1500 1596 8154 D4:01:C3:22:75:54
3 ether4 ether 1500 1596 8154 D4:01:C3:22:75:55
4 ether5 ether 1500 1596 8154 D4:01:C3:22:75:56
5 ether6 ether 1500 1596 8154 D4:01:C3:22:75:57
6 ether7 ether 1500 1596 8154 D4:01:C3:22:75:58
7 ether8 ether 1500 1596 8154 D4:01:C3:22:75:59
8 sfp1 ether 1500 1596 8154 D4:01:C3:22:75:5A
9 R lo loopback 65536 00:00:00:00:00:00
[admin@MikroTik] >
I removed the wifi interface manually (...
Tried a factory reset. I tried to upload the firmware and reset it to factory settings - it doesn’t work.
I also tried to create it manually via WUI - it doesn’t work, since there is no way to select a master interface. Same thing through the command line.
How can I restore it?
Check if wifi-qcom package is installed.
If it’s not, you did something more rigid then factory reset (possible action: netinstall but only base package used ?).
You need that package for wifi to work.
Check extra packages on Mikrotik download site for ARM, in there you will find wifi-qcom package.
I checked the packages. The extended package has been installed. But it was the package you specified that was disabled. After turning it on and rebooting the router, the interface created itself. Thanks for the help!
