How to dedicate a specific Ethernet port and wlan too , to a VPN connection
Hi, i have a connected , and running vpn connection set up . all i want to do now is to be able to use it via a specific ethernet port like port 4 , and wlan too so i can connect my android tv to it . please help please
using simple webfig rather than command lines please .
What type of VPN.
post your config
/export file=anynameyouwish ( minus router serial number and any public WANIP information, keys etc.)
i can connect both ovpn and l2tp ,
..on the vpn i purchased
what parameters you need my friend ?
like i said , the connection is up and running “connected” and “running” .
All i’m asking for is a way to dedicate and assign an ethernet port and wlan to broadcast this vpn .
port 1199
auth SHA1
cipher AES-256-CBC
redirect-gateway def1
auth-user-pass
this is the info i extracted by opening the ovpn config file
i only need to redirect the vpn connection to one of my ethernet ports and wireless too so i can use it on my android tv please.
is this pic enough ?
please help . please
using simple webfig preferably , i can disable firewall too .
