How to delete a RAM allocated folder
Hello.
Is it possible to remove a folder created with
/disk add type=tmpfs tmpfs-max-size=100M
as per https://help.mikrotik.com/docs/display/ROS/Disks#Disks-AllocateRAMtofolder?
By issuing the command
/disk print
the result is:
SLOT INTERFACE SIZE FREE FS
0 M tmp1 ram 100 003 840 99 995 648 tmpfs
1 M tmp2 ram 100 003 840 100 003 840 tmpf
Thank you!
Best regards.
