how to delete log history...?
can someone tell me how to delete log history…?
currently only way to clear logs is to set line count to 1 and after that line count to previous value
/system logging action
set memory memory-lines=1
set memory memory-lines=100
so you mean log history can not be delete or clear…?
NO, I said that it can be done with method mentioned in my previous post.
I have also tried this and the log cache is still full
r.os. version is 2.9.5
The logs list is now enormous and winbox is running very slow
someone please…helppppppp
Mikrotik: can a feature be added to winbox on only shot last 100 or something like |more or |tail -
and a button to FLUSH the LOGS and keep the last eg. 100
upgrade will probably fix you issue
