hi,
sorry my english
wire port ip range : 192.168.0.x
wireless port ip range : 192.168.1.x
i want wire & wireless route possible
how to routeing table setting?
thanks
hi,
sorry my english
thanks
Not sure what your wanting.
It looks like you have routes established to your wired and wireless ports as well as a few others that we cannot see.
If you do not have your route to the internet you will need to add that : 0.0.0.0/0 and gateway.
You will also need a masquerade rule under firewall/nat.
Hope that helps if not let us know.
In general, your configuration should be perfect - as mwarren77 said, it’s not clear what your goal is here.
If you want wired devices to be able to communicate with wireless devices, then this should already work - if it doesn’t work, then the problem is almost certainly in your firewall filter rules - the FORWARD chain.
Make sure that the forward chain does not block communication between the two networks.
thanks answer.
i want different local ip range (wire(bridge) : 192.168.0.x to wireless(bridge) : 192.168.1.x) possible communication
/ip firewall filter settings
0 D ;;; special dummy rule to show fasttrack counters
chain=forward
1 ;;; defconf: accept establieshed,related
chain=input action=accept connection-state=established,related log=no log-prefix=""
2 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp log=no log-prefix=""
3 ;;; defconf: accept ICMP
chain=input action=accept protocol=igmp log=no log-prefix=""
4 ;;; defconf: accept ICMP
chain=input action=accept protocol=gre log=no log-prefix=""
5 ;;; defconf: drop all from WAN
chain=input action=drop in-interface=ether1-WAN log=no log-prefix=""
6 ;;; defconf: drop all from WAN
chain=input action=drop in-interface=ether2-WAN log=no log-prefix=""
7 ;;; defconf: drop all from WAN
chain=input action=drop in-interface=ether3-WAN log=no log-prefix=""
8 ;;; defconf: drop all from WAN
chain=input action=drop in-interface=ether4-WAN log=no log-prefix=""
9 ;;; defconf: drop all from WAN
chain=input action=drop in-interface=ether5-WAN log=no log-prefix=""
10 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related,new log=no log-prefix=""
11 ;;; defconf: accept established,related
chain=forward action=accept connection-state=established,related,new log=no log-prefix=""
12 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
13 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1-WAN log=no log-prefix=""
14 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether2-WAN log=no log-prefix=""
15 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether3-WAN log=no log-prefix=""
16 ;;; defconf: drop all from WAN not DSTNATe
/ip firewall nat settings
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=wire_bridge log=no log-prefix=""
1 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=wireless_bridge log=no log-prefix=""
2 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=ether1-WAN log=no log-prefix=""
3 chain=srcnat action=masquerade out-interface=ether2-WAN log=no log-prefix=""
4 chain=srcnat action=masquerade out-interface=ether3-WAN log=no log-prefix=""
5 chain=srcnat action=masquerade out-interface=ether4-WAN log=no log-prefix=""
6 chain=srcnat action=masquerade out-interface=ether5-WAN log=no log-prefix=""
7 chain=dstnat action=dst-nat to-addresses=192.168.0.220 to-ports=80 protocol=tcp dst-address=164.125.153.126 dst-port=80 log=no log-prefix=""
/ip firewall address settings
# LIST ADDRESS TIMEOUT
0 wire_port 192.168.0.0/24
1 wireless_port 192.168.1.0/24
thanks answer.
Please see http://forum.mikrotik.com/t/how-to-different-ip-range-routing/97291/1
I don’t think you want to match NEW connections in your allow/fasttrack rules in the forward chain - that’s… quite dangerous - it basically means “no firewall”
Given that you have 3 wans, almost certainly your problem is because you’re doing a load-balancing thing.
You can override the policy routing with a routing rule:
/ip route rule add dst-address=192.168.0.0/16 action=lookup-only-in-table table=main
Thank you. Successful ![]()
