I agree with you, fewi, it should not be necessary to disable the queues… just adjust them. Thank you very much for helping!
The topology is as follows:
WAN: Comcast modem (50/10), 5 static IPs. Only 1 IP is used - configured on RB450G Eth1.
HotSpot: Eth2 connected to Dell switch . 10.10.15.0 /24
InternetCafe: Eth4 (12 workstations): connected to different switch. 10.10.16.0 /24
If I connect my laptop straight to the Comcast cable modem, and assign it a public IP, it works fine and pages load quickly. So something is going on inside of the RB450G…
I tried:
adjusting the Interface Queue “queue type” on eth1, 2, 4 to “default”, PFIFO and increasing the number to 50, 100, 200 packets. It’s a complete crawl at 10-50, but a little better at 200 or so.
There were also some entries in Firewall that were red/invalid. I deleted those.
Complete configuration attached:
MikroTik RouterOS 4.10 (c) 1999-2010 http://www.mikrotik.com/
file -- File name
hide-sensitive --
[username@PostMikrotik] > export
# jan/01/1970 16:07:47 by RouterOS 4.10
# software id = ID94-PKAP
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
comment="" disabled=yes forward-delay=15s max-message-age=20s mtu=1500 \
name=bridge priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:54:CC:B2 \
master-port=none mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:54:CC:B3 \
master-port=none mtu=1500 name=ether2-PostWiFi speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:54:CC:B4 \
master-port=none mtu=1500 name=ether3-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:54:CC:B5 \
master-port=none mtu=1500 name=ether4-IntCafe speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=\
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:54:CC:B6 \
master-port=none mtu=1500 name=ether5-local speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1 \
switch-all-ports=yes
/ip hotspot profile
set WiFiServerProfile dns-name="" hotspot-address=10.10.15.1 html-directory=\
hotspot http-proxy=0.0.0.0:0 login-by=http-chap name=WiFiServerProfile \
rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot
add disabled=no idle-timeout=5h interface=ether2-PostWiFi keepalive-timeout=\
none name=PostWiFi profile=WiFiServerProfile
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name="Post Wi-Fi pool" ranges=10.10.15.2-10.10.15.254
add name="Post .11 pool" ranges=192.168.11.10-192.168.11.200
add address-pool="Post Wi-Fi pool" authoritative=after-2sec-delay \
bootp-support=static disabled=no interface=ether2-PostWiFi lease-time=1h \
name=PostWiFi
add address-pool="Post .11 pool" authoritative=after-2sec-delay \
bootp-support=static disabled=no interface=ether5-local lease-time=1d \
name=PostMGR
/ip hotspot user profile
set WiFiUserProfile address-pool="Post Wi-Fi pool" idle-timeout=4h \
keepalive-timeout=4h name=WiFiUserProfile shared-users=unlimited \
status-autorefresh=5m transparent-proxy=no
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default \
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
only-one=default use-compression=default use-encryption=yes \
/queue type
set default kind=pfifo name=default pfifo-limit=200
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=250
set wireless-default kind=pfifo name=wireless-default pfifo-limit=250
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=pfifo name=hotspot-default pfifo-limit=250
set default-small kind=pfifo name=default-small pfifo-limit=250
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
direction=both disabled=no dst-address=0.0.0.0/0 interface=\
ether2-PostWiFi limit-at=0/0 max-limit=0/0 name=queue1 parent=none \
priority=8 queue=default/default target-addresses=\
10.10.15.0/24,10.10.16.0/24 total-queue=default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=\
backbone type=default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location="" \
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set Serge address=192.168.11.1/32 authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=\
DES name=Serge read-access=no security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass\
word,web,sniff,sensitive,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb\
ox,password,web,sniff,sensitive,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy\
,test,winbox,password,web,sniff,sensitive"
add bridge=bridge comment="" disabled=no edge=auto external-fdb=auto horizon=\
none interface=ether2-PostWiFi path-cost=10 point-to-point=auto priority=\
0x80
none interface=ether3-local path-cost=10 point-to-point=auto priority=\
0x80
none interface=ether4-IntCafe path-cost=10 point-to-point=auto priority=\
0x80
none interface=ether5-local path-cost=10 point-to-point=auto priority=\
0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
no
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:B6:7C:EA:E4:2E \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.10.15.1/24 broadcast=10.10.15.255 comment=\
"default configuration" disabled=no interface=ether2-PostWiFi network=\
10.10.15.0
add address=192.168.11.1/24 broadcast=192.168.11.255 comment="" disabled=no \
interface=ether5-local network=192.168.11.0
add address=173.164.123.456/29 broadcast=173.164.123.456 comment="" disabled=\
no interface=ether1-gateway network=173.164.123.456
add address=10.10.16.1/24 broadcast=10.10.16.255 comment="" disabled=no \
interface=ether4-IntCafe network=10.10.16.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
default-route-distance=1 disabled=no interface=ether1-gateway \
use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=10.10.15.0/24 comment="" dns-server=10.10.15.1 gateway=10.10.15.1 \
netmask=24
add address=192.168.11.0/24 comment="" dns-server=192.168.11.1 gateway=\
192.168.11.1 netmask=24
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=512 servers=68.87.76.178,68.87.78.130
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=input comment="default configuration" disabled=no \
protocol=icmp
add action=accept chain=input comment="default configuration" \
connection-state=established disabled=no in-interface=ether1-gateway
connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no \
add action=masquerade chain=srcnat comment="default configuration" disabled=\
no out-interface=ether1-gateway
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=10.10.15.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
set ftp disabled=yes ports=21
/ip hotspot user
add comment="" disabled=no name=usa password=hostels profile=WiFiUserProfile
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept comment="" disabled=no dst-address=193.95.456.789 server=\
PostWiFi
/ip neighbor discovery
set ether1-gateway discover=no
set ether2-PostWiFi discover=yes
set ether3-local discover=yes
set ether4-IntCafe discover=yes
set ether5-local discover=yes
set bridge discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
0.0.0.0
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
173.164.123.567 scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=default
set ether2-PostWiFi queue=default
set ether3-local queue=ethernet-default
set ether4-IntCafe queue=default
set ether5-local queue=ethernet-default
set bridge queue=default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=America/Los_Angeles
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=PostMikrotik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
add disabled=no interface=ether2-PostWiFi
add disabled=no interface=ether3-local
add disabled=no interface=ether4-IntCafe
add disabled=no interface=ether5-local
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 \
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=\
yes interface=all memory-limit=10 memory-scroll=no only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
