I am a beginner in mikrotik configurations and my english isn’t very well…
I would know how to disable connected routes when one interface isn’t running; indeed, I have two routes for the network LAN, one directly connected to my first mikrotik and one via my second mikrotik but the connected route is always up even if I unplug my ethernet cable… I don’t know how to do to prioritize my second route when my first cable is unplug.
I can try to give you more informations if you need.
Thank you for your answer but I just want to prioritize the second path when the first (directly connected) is down; indeed, even if the cable is unplugged the route stay up and the packets don’t take the other way…
Anybody knows how I can change that? Have I to use scripts?
On cisco with the function keepalive when the interface is down the connected routes are down too…
I think it is the only option too… but in my case it isn’t a solution because I have vrrp on these interfaces and if I disable the ip address, the vrrp won’t work as well as I want.
I really don’t understand why it is not automatic to disable connected routes when the interface goes down… I find that amazing…
