Hi all,
i am new to linux
i want use L7 filter without using connection tracking,
can any body tell me how to disable connection tracking
i need solution urgently,
reply must
Hi all,
i am new to linux
reply must
Hopefully you are new to Mikrotik, or you have the wrong forum.
Go to ip - firewall - connection - tracking. Take out the mark at connection tracking. That said, you wont be able to use firewall to filter any thing if connection tracking is disable.
You also won’t be able to use NAT.
you will be able to filer on per packet basis but you will not have nay connection information.
L7 filter requires connection tracking.
From:http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Connection_tracking
Features affected by connection tracking
