I want to disable dynamic ip assignation to computer with static IP in hotspot, how can i do ?
Set the address pool of the Hotspot instance as well as all user profiles used by it to ‘none’.
I want that one user with a static ip can not use the hotspot, with “none” the hotsopt convert the static ip in one of the dhcp pool.
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot#IP_Bindings
Make an IP binding of type blocked.
