Is there a quick and easy method to do this? On Cisco it’s just “no ip unreachables”
I want ICMP enabled for all src & dst addreses, but if a device is unreachable, I just want the packet dropped, no reply. Causing havoc with ICMP based network monitoring tools.
should prevent any such ICMP packets from being forwarded through the router. If you want to prevent RouterOS itself from generating such messages dropping them in the output chain should do the trick.
