How to disable login prompt for console connection
Hey folks, I want to be able to have user login only for web and ssh services but console should immediately drop me to command line. Is there a way to do this?
The problem I’ve ran into is that for whatever reason, if you re-enable a disabled default admin account, and then disable it again, it breaks all the user accounts including both the default admin and custom ones you’ve made. In a recovery mode I’d rather avoid having to reset to defaults again.
Thanks.
So report it as a bug. If this is true, I am sure MT would fix it very quickly.
