How to disable reset button in RB951Ui-2nD with rOS 6.32.4?
I have several RB951Ui-2nD but RouterOS 6.32.4 and I want to disable reset button.
I have tried the command:
/system routerboard settings set enable-jumper-reset=no
but it doesn’t work.
Someone know how to disable reset button using commands?
Thanks a lot,
Hi VikTik
I have the same problem, you managed to fix it?
