how to disallow download on RouterOS v3.11
pls i need someone to help me on how to disallow files like .exe, mp3 mpeg,avi from downloading on routerOS 3.11
have being try this rule and is not working
First, Configure Proxy.
/ip proxy
enabled: yes
src-address: 0.0.0.0
port: 8080
parent-proxy: 0.0.0.0:0
cache-drive: system
cache-administrator: “webmaster”
max-disk-cache-size: none
max-ram-cache-size: none
cache-only-on-disk: no
maximal-client-connections: 1000
maximal-server-connections: 1000
max-object-size: 512KiB
max-fresh-time: 3d
Now, Make it Transparent
chain=dstnat protocol=tcp dst-port=80 action=redirect to-ports=8080Make sure that your proxy is NOT a Open Proxy
chain=input in-interface= src-address=0.0.0.0/0 protocol=tcp dst-port=8080 action=dropNow for Blocking Websites
/ip proxy access
dst-host=www.vansol27.com action=deny It will block website http://www.vansol27.com/, We can always block the same for different networks by giving src-address. It will block for particular source address.
We can also stop downloading files like.mp3, .exe, .dat, .avi,…etc.
/ip proxy access
path=.exe action=deny
path=
.mp3 action=deny
path=.zip action=deny
path=
.rar action=deny.
I use “!192.168.0.1” in otherwords any address not destined for the routers’ web port address to start the redirrect..
I have seen this…
Try DstNAT (router address (the address of the port the users “see” as their gateway) to port 8080
in other wirds rty a dstNAT as the action to the local proxy..
