how to do that scenario??
I need for help please to setup mikrotik router Os according to that diagram:
and what about radius server
need for help please>>>
Yes, you are welcome. . . .
as your diagram, i try to little benefit you as you want.
better RouterOS when you will buy Mikrotik’s license by level 6 [more features]
  • RouterOS and Userman can use same machine.
  • dhcp-client config to public interface.
  • dhcp-hotspot server config to local interface.
  • dynamic ip address or and pppoe server enabled
  • dynamic ip address config to your infrastructure.
  • wds support every AP is must.
  • ip-binding metode on routerOS ip address infrastructure for.
try and find at wiki.mikrotik.com for more sample. and transparant network should be consept. it will easy to user make connect to your main gateway & control them while relax wihout any config to user machine. :wink: it’s promise to you.
reagrds
Hasbullah.com
Thanks for reply..
I’m already have license 6 with mikrotik router os 2.9.27
but i’m beginner and i’m already stuck with how enter wds repeater and other Aps to mikrotik router and how to control users of APS AND ROUTES
So please i need more help form you…
Hello fren,
oh.. . . nice.
before continue, please update your routerOS to newest version first, and you will get more critical security updates. and free for update without charge. many people will help you. don’t worry. . . . . . :wink:
regards
Hasbullah.com
Thanks again for reply
I’m now doing update
but i really need instructions little about ap’s (wds+other ap’s) and with routes in mikrotik…
please give me little instructions to do because i can’t deal with it in interface wireless
and thanks again for your help
