Why don’t you just permit the traffic to one address then deny remaining forwarding traffic? I don’t see any need for mangle rules on the basis of what you described so far.
Hmm… may be I am was not clear enough, let me restate the problem.
I want to block all packets incoming from internet (port wan) that have destination address of any private network (10.* 192.168.*). Clearly there should be no such packets routed around internet, but just in case there is one I want to block it.
This needs to be done early in prerouting as dstnat (port forward) will rewrite other legal packet to my network (e.g, src=1.x dst=2.x) dst address and such rewritten packet (src=1.x dst=10.x) in forward chain would be indistinguishable from rouge packet (e.g, src=1.x dst=10.x) entering wan.
Block such traffic in forwarding but earlier in the forward chain permit the paths necessary for the DST NATed traffic. In a firewall the default should be to deny traffic and only explicitly permitted traffic should be able to pass.
Sure - you can simply allow traffic to a wider range of IPs/ports than each individual DST NAT needs in order to cover them all. That would not be recommended from a security perspective.
I am using this set of rules. Why do you not consider them optimal? I don’t see any dropping options during Prerouting.
specifically dont know how how to make “dst=private-nets and dst!=R2-ip-addres”
In general, mark one connection or packet with, say, “predrop” where dst=private-nets, then have the second rule act on connections or packets where mark is predrop, and finally mark them “drop”.
