There are many strance IP address in hotspot / hosts list. Some of them my mikrotik’s gateway and it is a big problem for me.
I want to drop spesific IP and IP blocks from hotspot > hosts list automatically. How can i do that ?
You can’t. The hosts list dynamically shows all hosts th Hotspot has seen traffic from. Even if you removed them they would come back when they send another packet towards the Hotspot.
Is there another way that you can suggest ?
Redo your network design and layout so the IPs you see leaking don’t leak. Or ignore the entries in the host table. The entries exist because the Hotspot sees that traffic. Either ignore them, or design your network in a fashion so the Hotspot doesn’t see that traffic. If you need more specific advice post a screenshot of the hosts table and an accurate, well-labeled network diagram.
