How to dump 411AR hardware configuration ?
We have a 411AR<–>411AR bridge configuration. I’d like to buy an identical 411AR to add on a second station.
Is there a command from the terminal or Winbox that will tell me exactly which wireless card was added ?
Thanks,
Ward
When you say “wireless card”, are you referring to the wireless card on the new 411AR board? Or maybe after you connect the new board up as a second station, you are wanting to look on the original 411AR AP Bridge unit to see which new device was added?
If you want to see wireless card info on a particular board, you could do this while logged into that particular board:
/interface wireless info print
If you want to see the Registration List on the AP Bridge unit to see which devices are associated, do:
/interface wireless registration-table print
Hi Skot,
Sorry - I missed your response. Thanks for the quick reply !
Ward
