How to edit and delete added IP address
Hi Guys,
I’m totally new bie in configuring routerOS, currently I’m using
C# as my way of communicating to the rourterOS, I use the Api example there at the wiki api documentation and it works, my problem is how to edit and delete the added IP Address, this is how I add new IP
router.Send(“/ip/address/add”);
router.Send(“=address=192.168.1.1/24”);
router.Send(“=network=10.10.10.0”);
router.Send(“=broadcast=10.10.10.255”);
router.Send(“=interface=ether1”);
router.Send(“=disabled=no”);
router.Send(“.tag=aaa”, true);
I tried this statement for removing IP but an error occured
router.Send(“/ip/address/remove”);
and for updating something like this
router.Send(“/ip/address/set”);
by the way I’m currently using the latest version of the routerOS
Thanks in Advance
try this one
router.Send(“/ip/address/print”);
after that it will give you the IP address and the value number on the left most side, usually it is “0”
you can try this
router.Send(“/ip/address/remove/0”);
Cool, thanks alot
first, you should execute something like
/ip/address/print
=.proplist=.id
?address=what_you_want
to get identifier of the item. then
/ip/address/remove
=.id=your_id
hi people!! i need your help!!
i begin in that world and i need to know how i can do to send son command with the php api.
i realy need to disable and enable whith that api
note:sorry, i know my inglish is so bad!!! but i need your help please
well, looking at ‘inglish’, I think that it’s not a machine translation… so please explain us, what is ‘son command’ =)
also, when you add some item in return value you receive .id field value of the item you just added, then you can remove the item using that .id value
The remove command is not working.
/ip/address/remove
=.id=your_id
I tried this one
/ip/address/remove
=.id=4
and also this one
/ip/address/remove
=.id=*4
nothing happen, I always receive this message
!trap=message=no such command.tag=sss
!done.tag=sss
Ignore my last message it is now working..
I used this code
router.Send(“=.id=*4”);
Thanks alot guys and GOD BLESS
Guys, I’m trying to set queue comment trough api using the following command but seems not be working
Send(“/queue/simple/set”);
Send(“=.id=7/comment=test”);
does anyone knows how to solve it ?
Send("/queue/simple/set");
Send("=.id=7");
Send("=comment=test");
you’re funny, but this topic is about API, not about Terminal, SSH or whatever
